configure inline-power disconnect-precedence
                configure inline-power disconnect-precedence [deny-port | lowest-priority]
        Description
      Configures the disconnect precedence priority for the switch when a new
                PD is detected and the measured inline power for that switch or specified slot is
                within 19 W of the switch‘s or slot‘s PoE power
                budget.
        Syntax Description
                                deny-port
                            Specifies power be denied to
                                PD requesting power, regardless of priority. |
                                lowest-priority
                            Specifies power be withdrawn
                                from lowest-priority port(s) when next PD requesting power
                                connects. |
        Usage Guidelines
      You configure this parameter for the switch and for the entire
                SummitStack; you cannot configure this per slot or per port.
      If the power supplied to the PDs on a switch or specified slot exceeds
                the power that was budgeted for that switch or specified slot, the system
                disconnects power to one or more ports to prevent power overload.
      You configure the switch to either deny power to the next PD that requests power on that
                switch or slot, regardless of the priority, or to disconnect those PDs on ports with
                lower priorities until there is enough power for the new PD. If you select this last
                argument and you did not configure port priorities or if several ports have the same
                priority, the switch withdraws power (or disconnects) those ports with the highest
                port number (s). For information about configuring the PoE priority for the ports,
                see configure inline-power
                        priority ports
      The
default value is deny-port. So, if you do not change the default
value and the switch‘s or slot‘s power is exceeded, the next PD
requesting power will not be connected.
      When the setting is
lowest priority, the switch continues dropping ports with the lowest
configured PoE port priorities, or the highest port number in the
case of equal PoE port priorities, until there is enough power for
the requesting PD.
            When deny port is configured when ports are given priority, priority
                overtakes deny port action.
      The following command
sets the switch to withdraw power from the lowest-priority port(s):
      configure inline-power disconnect-precedence lowest-priority
      This command was
first available in ExtremeXOS 11.1.
        Platform Availability
      This command is available on:
                    - ExtremeSwitching
                            5420F-8W-16P-4XE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420F-24P-4XE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420F-16MW-32P-4XE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420F-16W-32P-4XE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420F-48P-4XE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420F-48P-4XL—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5420M-16MW-32P-4YE—ExtremeXOS 31.3 and
                        later.
                    - ExtremeSwitching
                            5320-48P-8XE—Switch Engine 31.6 and
                        later.
                    - ExtremeSwitching
                            5320-24P-8XE—Switch Engine 31.6 and
                        later.
                    - ExtremeSwitching
                            5320-16P-4XE—Switch Engine 31.7 and
                        later.
                    - ExtremeSwitching
                            5320-16P-4XE-DC—Switch Engine 31.7 and
                        later.
                    - 4220-12P-4X—Switch Engine 32.7.1 and
                        later.
                    - 4220-24P-4X—Switch Engine 32.7.1 and
                        later.
                    - 4220-48P-4X—Switch Engine 32.7.1 and
                        later.
                    - 4220-4MW-8P-4X—Switch Engine 32.7.1
                        and later.
                    - 4220-4MW-20P-4X—Switch Engine 32.7.1
                        and later.
                    - 4220-8MW-40P-4X—Switch Engine 32.7.1
                        and later.
                - ExtremeSwitching 5520-24W—ExtremeXOS 31.1 and later.
                - ExtremeSwitching 5520-48W—ExtremeXOS 31.1 and later.
                - ExtremeSwitching 5520-12MW-36W—ExtremeXOS 31.1 and later.
                - ExtremeSwitching 5420F-8W-16P-4XE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5420F-16MW-32P-4XE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5420F-16W-32P-4XE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5420M-24W-4YE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5420M-16MW-32P-4YE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5420M-48W-4YE—ExtremeXOS 31.3 and later.
                - ExtremeSwitching 5720-24MW—Switch Engine 32.1 and later.
                - ExtremeSwitching 5720-24MXW—Switch Engine 32.1 and later.
                - ExtremeSwitching 5720-48MW—Switch Engine 32.1 and later.
                - ExtremeSwitching 5720-48MXW—Switch Engine 32.1 and later.
                - 4120-24MW-4Y—Switch Engine 32.7 1 and
                    later.
                - 4120-48MW-4Y—Switch Engine 32.7 1 and
                    later.
                - 4220-4MW-8P-4X—Switch Engine 32.7 1 and
                    later.
                - 4220-4MW-20P-4X—Switch Engine 32.7 1 and
                    later.
                - 4220-8MW-40P-4X—Switch Engine 32.7 1 and
                    later.
